Hoover HD95M dishwasher. 32000010.
Original fault:- no heat and stopping on cycles (in heat positions). Heater, stats, pressure switch and wiring all check out OK. Clockwork timer… has to be that….. 🙂
Fit a new one and same fault!! Can’t understand it!
Tried the machine and the timer does switch the heater on for about 5 – 6 seconds then the timer moves on and the heater goes off again. The stats are a twin 88NC – OK; and the other is a 45 / 65 stat NA – checks OK.
The only thing I can think of is that there actually was a fault with the old timer unit and I may have got a wire wrong while changing it. So…..has anyone got a timer wiring diagram please so I can check it out? Even a wiring colour guide would help.
Thanks in advance,
Steve.
