Hoover DMCD1013BC-80 Tumble Dryer Error E15
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover DMCD1013BC-80 Tumble Dryer Error E15
  • #93270
    jontymox
    Good afternoon,
    Wondering if anyone can shed some light on the above error code, which I’m unable to find?
    The dryer is under two years old, and when a programme is selected the machine tumbles, and after a few seconds beeps, accompanied by displaying the above error code.
    This fault on some other Hoover dryers relates to a heat problem, and I’ve carried out a few tests on related items; ntc, heater and associated wiring, as there is no heat. (although may not generate heat anyway with error present)
    Do I suspect the electronic control module, (heater relay?) or should I be looking elsewhere?
    Kind regards,
    jonty
    #453765
    kaibart
    Re: Hoover DMCD1013BC-80 Tumble Dryer Error E15
    Yes pcb faulty kai
    #453766
    jontymox
    Thanks kai,
    Will provide customer with renewal quote.
    jonty
