hoover door hinge
  • #29550
    fasetester
    hi guys are there any difference in the hoover door hinge w/D the seem to be easy broken is there a cheap one and a good one or are the all the same if there is a good one what is the part number the door seems heavy the mod no is mw 6316m thanks fasetester 🙂
    #223579
    Re: hoover door hinge
    HW6316MUK?
    91700102.
    I buy them 5 at a time………
    fasetester
    thanks for the reply peng so is there a weaker hinge and a better quality one or are the all much the same the are not very strong would you put in new retainers when you are changing the hinge fasetester 🙂
    #223581
    Fitting the genuine one (91700102) is as good as it gets, and you won’t need to replace the retainers. Just tell your customer not to be so messy when using the dispenser as it’s usually detergent that corrodes the hinge in the first place! 😉
    #223582
    fasetester
    thanks guys for the replys fasetester 🙂
