HOOVER Double Oven
  • #100859
    suedehead1
    I need to replace a bas element on a top oven in a Hoover Double oven HDO909X I cannot see how it can be replaced.
    Has anyone any knowledge of how to replace it,
    thanks
    #482423
    probably from the rear as most of the elements are but you have to part the insulation to get access first
    suedehead1
    I must be missing something with this one the bottom oven base element has a slot to remove it,
    the top oven base element doesnt have a slot to remove it, it seems to be a complete dismantle to access it
    #482425
    can get a part breakdown but does not show in enough detail to guess how it comes apart
    suedehead1
    thanks Dave I will give it another go when I have more time
    #482427
    suedehead1
    hi, for anyone else attempting this job, the whole top cavity needs to be removed then insulation removed before access can
    be gained to the element
    #482428
    suedehead1 wrote:hi, for anyone else attempting this job, the whole top cavity needs to be removed then insulation removed before access can
    thats total madness
    suedehead1
    yes total madness even with the top cavity out it was still difficult changing the element , I spent a lot of time trying to do it in situ but it is not
    possible. I will not be in a rush to do another
