Re: Hoover drum lifters
I’ve done it before on different models. Access the screw via the sump, remove the screw you can access and then very gently (from in the the tub), break up the lifter. Bear in mind there may still be another screw holding it in. You’ve got to be really careful not to damage the drum.
Fit the new lifter and put one screw in via the sump again. Not sure if it is the same for this model but this is easier than the drum out scenaria.
Regards
RM
