Hoover dryer
  • #100193
    dopper
    its a vtc591b seems to work ok empty, but when wet load in,runs about 5 mins and clicks off, start button flashes no pause, its hot and steamy inside, press start again it will go for a sec only, not blocked
    Any pointers
    thanks
    #479677
    are you sure the condenser is not blocked shine a light through it to check
    kaibart
    Ahrer with dave on this try on timed dry if it’s the same will definitely be blocked condenser or air flow issue
    #479679
    dopper
    Hi its not blocked as can see my hand down it, and it was on a timed 60 min
    #479680
    are the drum seals ok ?
    was thinking condensation in the case as it only seems to happen with wet clothes in
    dopper
    Hi going to strip it down so will check
    #479682
    dopper
    Condenser is clear, i put it in a test mode think this code be a fault code? 3h lit 6h not 9h lit and the lights under ,1st one lit 2nd lit 3rd not, anyone got fault codes?
    #479683
    have emailed what i think are the fault codes
    dave
    #479684
    dopper
    Thanks for the codes, it wouldn’t do anything after putting in test mode, turned out to be the board, working good now
    Thanks for the help
