hoover dryer
  • #101841
    clockworkone
    Hoover hlc9df-80…….31101053. Dryer heats intermittently. what value should i be seeing on ntc.
    #486411
    kaibart
    You should have about 1 ohm on heater and front ntc when you measure it resistance will move high or low can’t remember full it this happens ntc will be fine more than likely to be pcb then
    #486412
    kaibart wrote:You should have about 1 ohm on heater and front ntc when you measure it resistance will move high or low can’t remember full it this happens ntc will be fine more than likely to be pcb then
    1 ohm does sound a bit low
    kaibart
    I mean 1 ohm across both stats on heater front ntc resistance will be different will be kohms up it will rise or fall I can’t remember
    #486414
    kaibart wrote:I mean 1 ohm across both stats on heater front ntc resistance will be different will be kohms up it will rise or fall I can’t remember
    that makes more sense
