Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hoover dryer dead
- This topic has 13 replies, 4 voices, and was last updated 18 years, 5 months ago by
abbots.
October 26, 2007 at 3:23 pm #31716
abbots
Participanthi,
HNC160-80
31100067this dryer is completely dead except for the red “on” light when start is pressed.
door interlock OK, supply OK, front red spot stat OK, had the drum out to check wiring and float switch, all seems OK.
Is there something i’ve missed or is it the timer maybe?
if so has any one a part number for it?
thanks.
johnOctober 26, 2007 at 3:32 pm #232263Martin
ParticipantRe: hoover dryer dead
I can send you the wiring diagram if that will help? 😉
October 26, 2007 at 3:35 pm #232264timdowning
Has this dryer got a display board on it with a triangular neon under the word start?
If it has then the on light comes on when the on/off button is pushed in. The triangular start neon should then flash until you press start.
If the on light is on but the triangular start neon dosen’t flash then I would assume the pcb is at fault.
Hope i’ve got the right model. 😕
October 26, 2007 at 3:41 pm #232265timdowning
p.s
If its not the model I said… it might be just the start pcb as on the previous range.
October 26, 2007 at 4:04 pm #232266abbots
if it’s the start relay why haven’t i got power to the heater?and i would have thought by keeping the on switch pushed in i would have got motor action untill i released the button.
johnOctober 26, 2007 at 4:12 pm #232267timdowning
On this model is it turn timer dial and press start?
Or is it turn timer dial, switch on/off switch on, and then press start?
October 26, 2007 at 7:15 pm #232268Penguin45
It has got the little start run PCB on board. If it won’t do anything at all, you’ve probably lost a neutral somewhere. Down the front near the pulley wheels is a good bet, or yes, perhaps the timer.
October 27, 2007 at 8:25 am #232269Martin
abbots wrote: i would have thought by keeping the on switch pushed in i would have got motor action untill i released the button.
That’s correct John, holding the start button in the motor would turn and at least you would hear the timer motor turning!
Do you want these wiring diagrams I have or what? 😉
October 28, 2007 at 1:46 pm #232270abbots
yes thanks martin,
sorry couldn’t send reply earlier had a few problems in the office.
thanks.
johnOctober 28, 2007 at 2:51 pm #232271Martin
I’ve just this minute emailed them to you John….. 😉
October 28, 2007 at 5:34 pm #232272abbots
thanks martin,
johnOctober 29, 2007 at 11:51 am #232273abbots
anyone got a part number for the timer on this model?
johnOctober 29, 2007 at 8:03 pm #232274Penguin45
04750236
October 29, 2007 at 9:04 pm #232275abbots
thanks chris
