Washer dryer HNWF6137
This machine keeps tripping the resettable stat to the dryer element (every month or so). What should i be checking on this to assertain why this is happening?
It’ll probably be a blocked condenser. Back panel off, lower hose from tub to condenser off (usually blocked solid) and rod out the fluff from below with a stiff wire. If you can’t get it all out from there, then remove the condenser completely, fiddly but possible. Reset the safety stat and all should be well.
