hoover dryer VHV180
  • #54691
    wilf
    this machine is making a noise like jockey pulleys as its a major job to strip down I want to have them at hand if I need them so I dont have to strip and reassemble twice anyone know part number ?
    thanks wilf
    #320655
    Re: hoover dryer VHV180
    I expect you mean a VHC180? Not a major strip down by any means to get to front drum support and the noisy pulleys (40004307). I find a clean up and squirt or two of 3 in 1 solves the noise as a rule. Same for the rear bearing. But if there’s any wear in that area then you’ll probably need a new drum shaft assy and a bearing kit (then it does get messy) and good luck with that job.:(
    Do you have a Connect account? If so you can look up the machine on Mediator to see what other bits you ‘might’ need to hand that way. 💡 😉
