Hoover dryer VHV680 Fault codes Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover dryer VHV680 Fault codes This topic has 12 replies, 5 voices, and was last updated 13 years, 2 months ago by roy1. Viewing 13 posts - 1 through 13 (of 13 total) Author Posts January 22, 2013 at 6:13 pm #73702 roy1Participant Hi does anyone know the fault codes for the vhv680 vision,the machine has indicator lights only. January 22, 2013 at 6:38 pm #388518 MartinParticipant Re: Hoover dryer VHV680 Fault codes What lights are showing then? January 23, 2013 at 8:03 pm #388519 roy1Participant Re: Hoover dryer VHV680 Fault codes All the lights start flashing after 2-3 mins of heating,i think it might be low ambient temp in the room. January 23, 2013 at 8:57 pm #388520 MartinParticipant Re: Hoover dryer VHV680 Fault codes Count the flashes = the error code! January 24, 2013 at 6:48 pm #388521 roy1Participant Re: Hoover dryer VHV680 Fault codes Thanks for that, what error codes are used for the vhd dryers. January 24, 2013 at 6:51 pm #388522 MartinParticipant Re: Hoover dryer VHV680 Fault codes roy1 wrote:Thanks for that, what error codes are used for the vhd dryers. Is that a separate question as I thought you were seeking info on a VHV dryer? January 24, 2013 at 7:49 pm #388523 roy1Participant Re: Hoover dryer VHV680 Fault codes Oops that should be vhv dryers, Thanks Roy. January 24, 2013 at 8:53 pm #388524 MartinParticipant Re: Hoover dryer VHV680 Fault codes roy1 wrote:Oops that should be vhv dryers, Check out the ‘Known Error Codes’ thread (last page I believe) 😉 January 24, 2013 at 9:22 pm #388525 advParticipant Re: Hoover dryer VHV680 Fault codes bet its broken wire on state on back o tub .or broken wire on dryer heater state at front under lid December 10, 2020 at 9:14 am #388526 mikehhaParticipant Roy did you manage to sort this dryer? I have the same problem I have checked all wires to heater and thermistor on front panel and one shot stat. so asumed it was board and its not! or thermistor ( all lights flashing no brakes ) December 10, 2020 at 9:54 am #388527 electrofixModerator have checked and the model above is not complete and i get 5 machine with quite a date range. its likley the technology will be different Dave December 10, 2020 at 12:00 pm #388528 mikehhaParticipant thanks dave its the top one vhv680c-80 31100398 December 10, 2020 at 1:49 pm #388529 electrofixModerator have sent you a test routine produced in early 2011 dont know if its relavant but its all good info just as an after thought sent you another email with the wiring Dave Author Posts Viewing 13 posts - 1 through 13 (of 13 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
