Hoover DT999 – Display shows E5
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hoover DT999 – Display shows E5
  • #29125
    johnnymitch
    Hi there ,
    I’m new to to this forum but I hope someone can help.
    I acquired a (used) Hoover DT999 recently – it was working OK in it’s previous home.
    I successfully ran it through a sterilising cycle – but on trying the real thing , after about 3-4 mins I get a warning bleep and E5 appears on the display.
    According to the manual, this means ‘Problem with Electronic Load Device’ – and the remedy is apparently ‘Call Service for assistance’.
    Before I bin this machine – because I’m not paying £93 for a callout- can anyone assist please?
    #221662
    Re: Hoover DT999 – Display shows E5
    It’s to do with water level control – the flow meter is not signalling correctly. This is a tubine and reed switch device which is supposed to signal to the computer board. I assume that it’s jammed at the very least, or possibly broken.
    Power off if having a poke about.
    johnnymitch
    Thanks penguin, that sounds like what the problem is. Can you tell me where the switch is located,please?
    In a worst case scenario – if it’s broken, what’s the answer – is it a part that can be replaced or is it too complicated because it’s linked to the computer board? 😕
    Any advice gratefully received
    Thanks again 🙂
    john
    #221664
    It’s a white plastic tube type gizmo under the machine, in-line with the inlet valve. If you’re lucky, it could just be a poor connection.
    It’s part number 91200523 if required – an email to spares@ukwhitegoods.co.uk will get things moving for you.
    johnnymitch
    Many thanks for your prompt advice, Penguin,
    I’m away for a couple of days, but I will let you know the outcome ASAP.
    This is a great service,
    Thanks again
    John 😀
    #221666
    johnnymitch
    Sorry it’s been a while Penguin – my couple of days away extended a bit.
    However, just to say that the dishwasher is up and running – thank you so much , it was what you said – the flow meter was jammed and was cutting off when the flow didn’t stop. A bit of a blowthrough and that was it!
    Thanks again,
    Saved me a bomb!
    Regards
    John 😀 😀
