I have a Hoover dxp410aib3 and it has just developed a e8 error. I have changed the motor and the fault is still there. It will work fine if I just put a really small load in to wash without the error coming up but with a heavier load the motor struggles to start up. Any advice would be helpful to try and sort it out. Thanks
Defective Tachometric Dynamo (opened or shorted) and/or Wiring.
Ohmic value of
Tachometric coil for the Motor by Ceset: 42 Ohm
Ohmic value of Tachometric coil for the Motor by Selni: 90 Ohm
Ohmic value of Tachometric coil for the Motor by Sole: 184 Ohm
