Hoover DYC 8913BX-S not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover DYC 8913BX-S not heating
  • #84878
    Irron
    I need help to diagnose the problem. Dryer machine not heating, and after start in few minutes show error code E08.
    On back side of dryer is heating element, on box of heating element is thermal fuse and high limit thermostat. All these elements have continuity. Inside of dryer I find two replacement termostats (sensor assy) and one thermostat similar to that one which exist on heating element box. I hoped that some of them do not have continuity, but unfortunately thay have. Now Im very confused, why my dryer not heating?
    Is it possible that electronic brains not work properly and problem in PCB?
    Any help or advise please!
    Thank you!
    #427059
    simon26r
    Re: Hoover DYC 8913BX-S not heating
    Hi.
    These machines show up a fault even with a low leakage on the element. Most I have looked at with E08 have needed a new element.
    I would guess you only have a box standard meter for checking over your machine that may not pick up the problem.
    #427060
    Irron
    simon26r wrote:Hi.
    Thank you for answer! Do you mean heating element?
