Hoover DYC7813NB-80
  • #101452
    Shroppyfly
    Hi experts ,
    So i have this dryer , its a model with the water collection tank inside the door, dryer itself works fine , quiet lol, condenses and drys the clothes, EXCEPT when the pump kicks in, GeeeeeUS, its like a Jet taking off , until it stops pumping ,.
    Now i know the model of the pump its a very standard widely used one, my query IS how on earth do you change it? , to me it looks like a drum out challenge at the least :mad:, unless it can be accessed by another method , or in fact can it be changed ?
    Cheers all
    James
    #484801
    no on those dryers its a drum out job
    very silly design difficult to do most repairs on those units
    kaibart
    Plus when you got the drum out its fiddley to get the pump removed
    #484803
    Shroppyfly
    Thanks guys yeah, id sorta resigned myself that a drum out job was the only way , but, had to ask, yeah very silly design, im guessing the pumps usually are very reliable usually so the location of it didn’t matter,I’ve no issues stripping it, just a flippin pain with Arthritic fingers what do you mean fiddly to change the pump? does the motor have have to come as well to access it? i mean the pump does pump…!, but its very very loud lol, odd is, when its pumping you tip the driver backwards, or sideways , on two feet , the noise stops, but as soon as you pop it back on all 4 feet its there, i think tomorrow ill swear at it a fair bit then attack it on Monday
    #484804
    Shroppyfly
    So as a finish off, when i wrote the initial post id turned the dryer upside down -to have a proper look, then the posts and confirmation, . So i stood there and swore at it a few hundred times, popped it back on its feet in prep for the stripdown, I thought id give it one last go , and Bingo, whatever was causing the high pitched whine has gone 😀 a few more loads to make sure and it hasnt returned, So success in a way…!
