I’ve got a DYN 7144 with similar issues…… on a short 14min cycle it goes great… it fills,heats and empties but comes up with E03 before filling up for rinses everytime. I’m thinking it can’t be the heater as it heats…… any other ideas please?
asp11 wrote:No nothing is blocked at all…… and it heats, which is why I did’t suspect the heater…… or can the heater still be at fault even though it heats??
correct the heater can have an earth fault which means it can still work but the earth current upsets the control board
you not going to know if its faulty unless you replace it or measure the resistance to earth with a insulation tester
