hoover DYN 7164DIX/1-80
  • #93354
    suedehead1
    usual E03, E10 fault checked for blockages none.
    then of course changed heater.
    fault e03 still there changed module,
    e03 still there.
    any ideas welcome.
    #454064
    Re: hoover DYN 7164DIX/1-80
    As you know the error E03 relates to drain time-out. So as long as you know that that is not the case then you have a very slight earth leak somewhere.
    Firstly, have you tested for earth leaks? If your megohm reading is less that 100 then that’s your problem.
    #454065
    kaibart
    Change the pump they do go on them
    #454066
    suedehead1
    thanks
    #454067
    alster
    Are you sure its not a blocked pressure pot??
    #454068
    suedehead1
    checked that thought it might be a pressure switch fault but I am going to try a pump first
    #454069
    kaibart
    Never changed a pressure switch on a Hoover candy washer they do not fail if the customer is over dosing do pull off pressure switch pipe at the tank end I have had a few block up due to overdosing this is a bit fiddly thou worth doing before you change the pump
    #454070
    suedehead1
    thanks for the advise you always come up with one which is a problem job
