[USER=”58994″]Si465[/USER] did you ever resolve this issue?
We have a wdyns654d with exactly the same symptoms. In our case the machine developed fault e08 and e07 – I replaced the motor brushes to resolve e08 and the machine now functions, however e07 persists with the same behaviour you state – the cycle successfully completes and the door unlocks after a short time, but the lock symbol on the led remains, it will then re-lock and display e07 after a short period.
Weird fault. Anyone else have any ideas? I dont want to replace the switch of is not at fault. Sounds like it is something else.
What is the “door switch” by the way? Some sort of combined solenoid and switch?
