Hello you good whitegoods people, Fault E08 motor fault, watched You Tube video on E08 fault. Replaced brushes on motor started on wash cycle, strange high pitched sound from motor, motor rotated upto 1400 rpm but high pitched sound appeared as revs hit certain points. Now sparking from brushes and motor stuttering and now machine registering E08 fault.
Motor tacho was 47.3 ohm at rest on spinning motor the resistance changed.
Due to sparking I suspect motor is kaput!
Thanking you all in advance – any ideas?
