hoover dyn10146p washer
  • #58575
    DRH
    any idea please. e15 code?
    #334966
    loopey
    Re: hoover dyn10146p washer
    ERROR CODE MOST PROBABLE REASONS FOR THE ERROR CODE:
    E:01 Defective Door Safety Lock Device and/or Triac on Power Module and/or
    Wiring.
    E:02
    The Water Fill Phase was not completed within the designed limit time.
    Defective Solenoid Valve, Pressostat, Water Fill Hose, Low Water Pressure in
    the network and/or Wiring.
    E:03 The Water Drain Phase was not completed within the designed limit time.
    Clogged Filter, Drain Pump, Drain Hose, Wall Discharge and/or Wiring.
    E:04 Several (3) interventions by the Anti-flood Safety Contact of Pressostat.
    Solenoid Valve blocked opened, defective Pressostat and/or Wiring.
    E:05 NTC Temperature Reading Probe opened or shorted and/or Wiring.
    E:06 Counter of Interventions by the Anti-unbalancement System (MEM readable
    only).
    E:07 Defective Door Safety Lock Device (blocked closed) and/or Wiring.
    E:08 Defective Tachometric Dynamo (opened or shorted) and/or Wiring.
    E:09 Defective “Cuore” Power Module (damaged Motor’s TRIAC) and/or Wiring.
    E:11 Open Circuit on NTC Probe for Drying and/or Wiring.
    E:12 Open Circuit on Drying Module and/or Drying Heater and/or Wiring.
    E:13 Defective “Cuore” Power Module and/or Wiring.
    E:14 Missing Water Heating: defective NTC Probe and/or defective Water Heating
    Element and/or Wiring.
    E:15 Not Programmed “Cuore” Power Module.
    E:16 Water Heating Element is short circuited or defective electrical insulation.
    E:17 Wrong signal from Tachometric Dynamo.
    E:18 Defective “Cuore” Power Module – Wiring – Wrong Network Frequency (with
    Knob Programs Selector).
    E:18 Power-ON Times Counter (with Soft Touch Programs Selector – see Technical
    Note 015lb09).
    Best regards.
    hsd to do a quick copy n paste got to go out
    hth phil
    #334967
    DRH
    many thanks.
