Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover DYN7164 310051781227 motor stammer
- This topic has 11 replies, 4 voices, and was last updated 9 years, 5 months ago by
alro.
October 18, 2016 at 7:13 pm #89631
alro
ParticipantHi gents
motor wont rotate no error code shown motor just has a stammer any ideas DC motor in machine rectifier or core board or motor any info would help me please
cheers alroOctober 18, 2016 at 7:26 pm #441928Mo3426
ParticipantRe: Hoover DYN7164 310051781227 motor stammer
had one last week were the splines on the drum pulley had stripped giving this effect untill i looked at the back of the machine
October 18, 2016 at 7:33 pm #441929alro
no checked pulley all ok motor stammers with no belt on
cheers alroOctober 18, 2016 at 7:58 pm #441930kaibart
ModeratorRe: Hoover DYN7164 310051781227 motor stammer
Check rectifier common to go due to overloading if the tracks are ok inspect main pcb or burn Mark’s hope this helps normally more than 1 problem with these dc machines thou.
October 20, 2016 at 8:39 am #441931alro
hI Gents still need help on this has no rectifier just a core board and DC motor any tech info would help so i can go back and test the machine cheers alro
October 20, 2016 at 5:46 pm #441932kaibart
Change module this will sort it for you connect have them in stock 5045382391334
October 20, 2016 at 5:48 pm #441933kaibart
You have checked the plug connector to the motor for a wiring fault if so definitely go with module
November 8, 2016 at 7:17 pm #441934alro
fitted new module still motor make a loud humming noise and stammer or judders but will not rotate what am i missing to check any help please cheers alro insulation on motor tested ok and reading on winding there need to know what reading should be
November 8, 2016 at 8:22 pm #441935kaibart
Have you fitted correct module part number for programmed module 49027632 sound like a module faulty to me
November 9, 2016 at 2:22 pm #441936alro
Yes fitted 49027632 same fault
November 9, 2016 at 2:26 pm #441937Martin
……and the motor plug is definately OK is it? Double checked continuity between it and the control module?
November 11, 2016 at 9:53 pm #441938alro
gents motor faulty fitted new one all ok
old motor reading same as new motor but it was no good just stammered thank all for replys cheers alro -
