Hoover DYN7164 Door not locking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover DYN7164 Door not locking
  • #90709
    neilsukwg
    DYN7164D1x/1-80
    3100558813356483
    Tried a new interlock on this 4 year old machine but no go
    Lock light flashes 10x then goes out door not locked
    What is likely solution?
    #445708
    kaibart
    Re: Hoover DYN7164 Door not locking
    Probably motor problem then what’s the insulation like?
    #445709
    codlets
    Had loads of hoovers with this problem, usually board gone. Did you solve it Neil ?
    #445710
    neilsukwg
    No went right through everything,
    Motor was good, heater a bit on the low side.
    Customer scrapped it after that but i was doing some research for next time..
    would i need a pre programmed board and do you know of a good source?
    #445711
    codlets
    To be honest i’ve never purchased a new one. The problems I had were when refurbishing machines so I used replacement pcb’s that I took off machines with bearings gone. Masterpart do stock them but it doesnt mention whether they are programmed or not
    #445712
    neilbow
    Yes I agree sounds like the Main Control Board, to order one you will need the the serial number which is on the label on the inside of the door it will begin 3100********, this will give the variant and date of manufacture as there are different boards depending on date of manufacture. The control modules are around £50.00 less discount plus vat, so is a do able job. If you want, send me the serial number and I can give you definite prices. Regards Neil
    #445713
    neilsukwg
    Thanks but machine was scrapped :tup:
