Hoover DYN7164D Filling at end of cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover DYN7164D Filling at end of cycle
  • #90877
    codlets
    I’m going to look at this washing machine tomorrow and according to the customer it completes a cycle, and then fills the drum with water, before ending.
    Anyone had this before ?
    #446306
    kaibart
    Re: Hoover DYN7164D Filling at end of cycle
    Only can be a water valve failure kai
    #446307
    codlets
    Yes i was thinking that, but they say its fills up rapidly then stops. Not slowly over time ?
    #446308
    kaibart
    Yea still sounds like a valve, the valve and pump used to be on the same connector on the old Nextra and either of those can cause the problem, but I’m pretty sure it will be the valve kai
    #446309
    codlets
    Thanks for your help Kai much appreciated
    #446310
    check its plumbed to cold. some Beko;s do that when they are plumbed to hot
    codlets
    Thanks Dave will check that too
    #446312
    codlets
    Ok so it turns out as soon as the door locked the machine started to fill regardless of what program was selected.
    Pulled the machine out and the bolts from the front weight were on the floor, along with a lot of concrete dust. #writeoff
    #446313
    and no one had noticed the noise it was making for weeks before failure lol
    get it all the time when you ask them they say “yes now you mention it, it did seem a bit noisy ”
    codlets
    Precisely Dave ! lol
    Leon
