Thanks Martin for your reply – i did check search first but there seemed to be no conclusive outcome on this fault. But there was enough for me to try a new door interlock first and that did not cure it – So is it likely just to be the motor or the power module as well ?
senseib wrote:So is it likely just to be the motor or the power module as well ?
I guess it must be a MDL coreboard fitted on your machine then, 3 phase motor is it? I have no idea what to suggest other than what the error code points the fault as being. According to the manual the resistors that protect the motor lie under that big heat sink. If they look blown that would meant the answer to your question must be yes!
