snig wrote:3100439913080590 machine is dead, no display. Would the wrong module still at least light up display ?
dont know if wrong board will cause problems but from that number you have correct board
assume you have checked power to the machine
was the board sealed, have had used faulty board from connect
the programme selector switches live on and off, is it working
my next action would be to check the power supply on the new board to see if its working
not sure if front panel has chips on it but if it has you may have blown that too
