Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover DYN8164DI-80 drum problem.
- This topic has 2 replies, 3 voices, and was last updated 14 years, 3 months ago by
aqualectric.
December 20, 2011 at 1:24 am #66971
aqualectric
ParticipantHoover DYN8164DI-80 9KG washer. 3100383410485506.
This machine is less than a year old and it has already had three heaters. This is a long standing customer and she was desperate to get the machine running as the manufacturer was quoting after Christmas to call.
E16 fault – heater short to earth. On removal of the heater I found damage to the top surface similar to the damage caused in old Hoover washers when the heater bracket rusted off and the heater flapped between the drum and tub. The underside of the drum holes have ground the heater away; eventually holing it. All the lugs on the drum paddles are missing. I also noticed that the stainless steel drum weld either side of the paddle that partially covered it was almost razor sharp. The drum is slightly out of round when spun by hand.
Firstly, is the exploding drum issue still going on; could this machine be about to fail? Secondly, the heater was definately secured by the wire bracket; so it wasn’t installed incorrectly. Thirdly, there were no foreign bodies in the tub, sump hose or filter.(apart from plastic paddle bits).
Which seems to suggest the drum is somehow hitting the heater.Any ideas? I think it’ll need a whole new (sealed) tub assembly. Anyone had this problem with this series? Any known issues?
Thanks,
Steve.December 20, 2011 at 8:22 am #365794Martin
ParticipantRe: Hoover DYN8164DI-80 drum problem.
aqualectric wrote:Any ideas? I think it’ll need a whole new (sealed) tub assembly.
Sounds like a write-off to me and must have had a duff drum from the beginning which the Gias boys failed to suss. 3 heaters in less than a year? How come they never figured that out? :rolls:
December 20, 2011 at 6:26 pm #365795leavemetogetonwithit
Martin wrote:How come they never figured that out? :rolls:
No incentive for them to bother with asking why things happen. Heater gone, replace it. 3rd time? Ok, another one should get it past the guarantee period. 9Kg for ****’s sake. How heavy is that going to be when it’s wet? :rolls:
Mike. -
