hoover dyn9164dpg
  • #89243
    eng14
    hi all this hoover will do several washes then go to error e03,took blocked filter out and cleared and worked fine then aborts any one seen this please,richard. 🙁
    #440783
    Re: hoover dyn9164dpg
    Element
    Bryan
    #440784
    eng14
    hello bryan tried element on another one still the same,seems to be a fault with these hoovers,thanks.
    #440785
    timdowning
    Just to clarify, what does ‘tried element on another one’ mean?
    #440786
    kaibart
    Meggar the appliance something will be low also the water valve links into the pump on some hoover machines
    #440787
    Check the air tube and bottle then as it’s not normally a problem other than showing E16 E3 and that is the heater even though they still heat up.
    Bryan
    #440788
    eng14
    I meant I had this on the same model some time ago,changed pump,heater etc still the same,will try air tube and valves,thanks.
    #440789
    timdowning
    Change the heater first. Make sure its the genuine version which comes with the NTC.
