Hoover DYN9164DPG 3100500913183080 Error: E08
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover DYN9164DPG 3100500913183080 Error: E08
  • #84879
    jontymox
    Good morning,
    Could anyone let me know if there is a test sequence for the above washing machine?
    The m/c will fill and briefly wash, before aborting with error E08
    This relates to a motor/brush/ecu fault.
    The m/c spins fine on fast spin, and is an induction motor, hence, no carbon brushes.
    Hope someone can assist.
    jonty
    #427061
    simon26r
    Re: Hoover DYN9164DPG 3100500913183080 Error: E08
    Have sent you a pm
    #427062
    jontymox
    Thank you so much simon26r,
    Will carry out test procedure in the next couple of days.
    Suspect motor…
    jonty
    #427063
    jontymox
    Well,
    I carried out the test procedure… thanks Simon, which confirmed error code E08,(defective tachometric dynamo, wiring or electronic control module!) so visually inspected the motor, tacho, wiring and ecm.
    All looked fine, so took a gamble and replaced the motor.
    Re-tested on a wash programme, and all well for around 40 minutes until error code E08 returned.
    Hence, I’m struggling to diagnose this fault… do these codes need cancelling via the diagnostic link in the ecm, and is there any way of testing the small module below the main ecm?
    I’m wary of replacing the ecm, if it is not at fault.
    jonty
    #427064
    jontymox
    Proved to be a fault in the electronic control unit.
    Renewed, and all well.
    jonty
    #427065
    ddirect
    Hi Jontymox with reference to your hoover e08
    When you say electronic control unit do you mean the main board or the little box sitting in front of the main board, any chance of a part number?
    #427066
    jontymox
    Yes, main board was faulty.
    Will try and locate part number, as it was over a year ago.
    jonty
    #427067
    jontymox
    The only part number I have is a Connect Distribution part no: 5045382385760
    which I trust helps.
    jonty
    #427068
    kaibart
    The part number for the programmed module is 49026463 which is out of stem with connect and special order with qualtex hope this help any queries on hoover / candy I’m your man ex bias engineer hope this helps you kai
