Hoover Dynamic 8+
  • #77296
    speedqueen
    Been to this machine which wont start. Door lock light is flashing and door not locking, yet the interlock is reading out ok. Any suggestions? thought i may just try a new interlock anyway but would like to have a back up plan if it still dosnt work. Its a DYN8144db/2-80
    cheers
    #401664
    aqualectric
    Re: Hoover Dynamic 8+
    Could be a faulty interlock; but if not look at the pump connections as I have had a couple of 8kg’s with the pump plug burnt. This in turn fries the triac on the module (can be seen easily as the triac looks as if a piece has been chipped off) and the reverse side of the PCB will be blown. PCBs come non – configured…….. 👿
    HTH,
    Steve.
    #401665
    speedqueen
    Righto – thanks. was hoping it wouldnt be a pcb. will try new interlock first and check pump if that dosent work.
