Hoover Dynamic next 9kg error codes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Dynamic next 9kg error codes
  • #101101
    Shroppyfly
    Hello Experts and hobbyists,
    So i have a WDXOA496C 1-80 washer dryer , unconnected to a water supply and put just into drying mode it grunts and groans before popping up error E09 Am i looking at a piece of scrap metal only fixed by a new control board at about 50 quid OR? is there a test mode i can pop it into to confirm this
    Thanks in advance all
    #483349
    kaibart
    The main module is at fault motor triac failure E-09 is kai
    #483350
    Shroppyfly
    The phrase “clucking bell” springs to mind so i need one of these yes [h=1]HOOVER WASHING MACHINE ELECTRONIC CONTROL NFC BLE PROGRAMMED for WDXOA496C/1-80 (31008689)[/h]
    #483351
    you can replace the triac on the board
    but beware i have also had the fault on other machines when the motor has an earth fault
    Shroppyfly
    Oh brilliant lol so how on earth would I check that possible error?
    #483353
    Shroppyfly
    Oh dy o mean I can replace the trial as a separate componant?
    #483354
    Shroppyfly
    Dave One presumes with an exceptionally steady hand and professional soldering equip, would it then req coding? To my machine and I’m presuming it’s a small electrical bit of kit, so where could I source it?
    cheers
    #483355
    sourcing it should be easy but first try testing with a meter
    as a first up
    remove motor, remove carbon brushes and dust off all carbon dust and replace
    then try it
    Shroppyfly
    Dave I will attempt to do without removing a painfully large {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of knuckle skin and report back
    Cheers
    #483357
    Shroppyfly
    So, before i did what i did today , i had a error code, but not much else , so i did what Dave suggested reassembled plugged and POP it tripped the trip switch, popped back up, now lcd display nothing and whichever setting its on , it seems to be filling and draining at the same time, not a happy bunny, anyhow removed the pcb and there does seem to be an area which looks cindered/burnt , but i could be imagining it , can you post pics on here?, i have to ad when i first reassembled with no water connected, it just hummed but zero lcd display, after some cussing , and connected to water it popped and is on permanent fill and drain your move Dave lol
    #483358
    Shroppyfly
    Project scrapped, onto the next 🙁
    #483359
    for future ref
    to post pics, host on another site and post a public link
