Hoover Dynamic Next problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Dynamic Next problem
  • #102522
    williams1956
    I asked this question a couple of years ago but I cant find the response. Occasionally the machine stops with 9 min left and sometimes shows error o3 which would suggest a blockage but I have checked all pipes and pump and all are clear. I have had the pump on the bench and it tests ok.I have also changed the heater element as someone suggested this could be at fault. Any help much appreciated.
    #489303
    andyjawa
    Have you got the actual model number AND the first 8 numbers beginning with a 3 as read off the rating label.
