Hoover dynamic next washing machine e22
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover dynamic next washing machine e22
  • #97316
    jay3005
    Hope someone can help ??
    HOOVER – WASHING MACHINE – DYNAMIC NEXT (NOT DRYER)
    ERROR CODE E22
    I have search the net for this error code but all I can find is Tumble Dryer E22 codes
    Has anyone seen this problem?
    Thanks Jk
    #467041
    to look anything up we would need the model and commercial code on the label inside the door
    jay3005
    Thank you for the response, Dave,
    As requested:
    MOD DXOA – 610AHFN – 80
    N: 3100790717450685
    #467043
    E22 is a heater fault
    jay3005
    Thank you,
    Would that be a new heating element? How would I need to check?
    Jk
    #467045
    you would need to get a multi meter and check the heater resistance
    jay3005
    Thank you, Dave.
    Element checked and the replacement arrived today.
    Installed and all working Fine.
    Easy to remove and replace.
    #467047
    Amar Jaha
    Hi electrofix,
    Happy new year in advance.
    I also have hoover washing machine with similar error code.
    model – DWOAD610AHF7-80
    , water starts filling and then e22 error shows after which water starts draining but doesn’t completely drain the water in the drum.
    Please help.!!! What could be the issue and any resolution.
    #467048
    this is what it says
    Amar Jaha
    Hmmm.. sorry Dave, if I wasn’t clear before. Its a washing machine not a dryer.
    #467050
    Dont ask my why i posted E12 instead of E22 must be a senior moment lol
    Amar Jaha
    Hi Dave,
    Happy new year !!
    Thanks for your support, can’t appreciate enough.
    got the machine looked at by an engineer and he said machine has a new pcb(motherboard at the back of machine )and all components look OK, but I still have doubts and on the code as well.
    I have ordered multimeter and its on its way but for now thought of running Drain and rinse cycle which doesn’t require water intake and I have recorded a small youtube video asking for help.
    https://youtu.be/MNlKJSMPqVA
    It shows weird behaviour with flickering and error.
    hope this gives more insight about the error.
    #467052
    difficult to know whay it flashes like that
    may be as simple as some sort of switch on self test that detects a fault in the end
    you wont know till you get a meter and see if its as simple as a blown heater
