Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover Family 1300 model HF 7130M UK Washing Machine
- This topic has 6 replies, 3 voices, and was last updated 13 years, 1 month ago by
harryf.
February 20, 2013 at 9:17 pm #74240
harryf
ParticipantMy machine failed to fill even after replacing inlet valve.
Fitted new coreboard mudule, machine now fills and wash cycle but fails to empty,
Can someone suggest how to gain access the pump ass’y., also is pump motor AC or DC? and what is operating voltage?
Thanks for any help. Harry F.February 20, 2013 at 11:01 pm #390546kwatt
KeymasterRe: Hoover Family 1300 model HF 7130M UK Washing Machine
Pump is behind the filter at the bottom.
It should rum on 220-240VAC.
February 21, 2013 at 9:41 am #390547iadom
ModeratorRe: Hoover Family 1300 model HF 7130M UK Washing Machine
Its possible the faulty pump damaged the pcb in the first place, and may damage the new one if you are unlucky. 😥
The pumps on lots of these Candy machines are situated below a couple of known leak points, and are often damaged by this. As well as the pump itself you need to examine the small connector plug the fits into the pump, they often short across after the water has dripped onto them.
February 22, 2013 at 10:23 am #390548harryf
ParticipantRe: Hoover Family 1300 model HF 7130M UK Washing Machine
Hoover Family 1300.
Thank you for your help.
Can you suggest how I gain access to examine pump/conector.
Regards.Harry F.February 22, 2013 at 10:26 am #390549iadom
kwatt wrote:Pump is behind the filter at the bottom.
February 22, 2013 at 10:49 pm #390550harryf
Thank you.
My problem is finding a way to removing the pump ass’y to check it out and possibly replace it. I have checked the pump’s rotor blades by removing the front kick-plate and filter. Is the only access via the machine’s base. (ie turning it on it’s side or back)?? Regards HarryFFebruary 22, 2013 at 11:25 pm #390551iadom
Tilted back is best,you will also need to check for leaks, the detergent inlet hose into the front of the drum is a prime suspect. It needs to be resealed if it shows signs of leaking.
