Re: Hoover Fault Codes
The time for the displaying of each code, is 15
seconds. During this period of time, both LEDs flash
together at the frequency of 1 Hz (one flash per
second), for a number of times corresponding to the
number of the error to be displayed. Then, they stay
OFF for all the time that’s missing to the end of the
period of 15 seconds. The sequence is repeated until
Service Intervention or until the machine is switched
OFF.
Example: Error Code Number 2 (missing completion
of the water load within the designed limit
time) is displayed as follows:
• 2 flashes by the 2 LEDs together, in
the first 2 seconds of the period of 15
seconds (0.5″ ON – 0.5″ OFF)
• For the remaining 13 seconds, both
LEDs stay of OFF.
• The sequence as above, is repeated.
ERROR 2
The Water Fill Phase was not completed within the designed limit time. Defective
Solenoid Valve, Pressostat, Water Fill Hose, Low Water Pressure in the network
and/or Wiring.
hope this helps
phil
