Hoover fitting paddles
  • #79619
    pmb
    Hoover VHD147a, two paddles have broken away, never had this on the Hoover
    They are screwed from the outside of the drum, I was hoping the screws would line up with the sump hole but no luck there,
    Does the tub come apart.
    Anyone done this repair ?
    #409989
    Re: Hoover fitting paddles
    Check this out…..
    #409990
    pmb
    Just looked up paddles for this model and theirs two types so I will have to go back
    And see which one, the ones on the machine are screwed in,
    Can anyone tell me if one type is screwed and one clicked in place and are they
    Interchangeable .
    #409991
    timdowning
    You can normally tell the difference by the pattern of the holes on the paddle. You can get the customer to describe whilst you look at the pictures on connect. I’m sure both types are originally screwed in.
    #409992
    It’s a welded tub though isn’t it pmb?
