Hoover fridge freezer HCA300FK – PCB
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover fridge freezer HCA300FK – PCB
  • #17796
    walnut
    Does anyone know the part number for the PCB on above fridge freezer?
    Fidge running constantly, freezing food in fridge compartment.
    Any help gratefully received.
    #176425
    whitevanman
    Re: Hoover fridge freezer HCA300FK – PCB
    There are 2 part nos 91201739 or 41007946 but I would tend to think that the thermistor buried in the insulation is at fault, can be tested using built in test diagnostic facility.
    Hope this helps
    Wvm
    #176426
    Dave_Conway
    It depends on the date, 91201739 is up to week 16 2003 and 41007946 after that date.
    I would agree with WVM, thermistor at fault, part number is 91201875 but quite how you’re meant to fit it…… 😉
    #176427
    walnut
    Thanks for the info,
    I cannot remember how to work the self test.
    Does anyone know where I can get a Service manual?
    #176428
    Dave_Conway
    walnut wrote:Does anyone know where I can get a Service manual?
    From your email inbox shortly 😆
    #176429
    walnut
    Muchas gracias
    #176430
    expertcat
    the thermister are a horrible job to fit only done one will never do it againg.
    They will give you a rough 3 inch square to cut into to find it.
    When you have found it pull it out replace it then fill it up with fix and foam polystyrene foam by polycell.Just make sure you have plenty of floor coverage because it will drip everywhere but you will find that in a few years the insulation breaks down at that point anycase because you have entered at that point.
    Hope this helps.
    #176431
    Simon46
    This isnt the model where the pcb PSU fails in the “run all the time freezing the milk syndrome” is it? Is the interior light working?
    Regards
    S.
    #176432
    walnut
    The customer reported that the light works but goes off when the dial is turned to 0, the compressor still runs on O
    According to what I can tell from the service manual the amber led should be flashing if the thermalprobe is faulty.
    Do you know what component fails on the PCB?
    #176433
    Simon46
    Doesnt sound like the usual dead PCB fault. QER repair my Hoover Candy modules. BobHope is an expert on these.
    Regards
    Simon
    #176434
    BobHope
    100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} pcb fault
    the .100uf yellow capacitor has failed.
    Bob.
    #176435
    walnut
    Which is the .100 uf cap?
    is it C6 rectangle cap with ‘J’ printed on it ?
    PCB = 91201739.
    #176436
    walnut
    Farnell Pt No – 303-8336 – 89p + vat.
    Ding Dang Do.
