Hi All,
I have a Hoover fridge freezer Model No. HF27C. It is totally “lifeless” – no sound, no interior light (bulb is ok ), no power indicator light at the external control panel.
The incoming power lead live terminal at the compressor relay terminal block is live ok. The resistance checks between compressor pins are 6, 6, and 20 ohms with no shorts to earth. That is the extent of my checks.
Do you have any ideas as to most likely cause – Faulty start relay (Danfoss 103N0021)? or faulty thermostat? Would either of these result in no interior light and/or no green ‘ON’ light at external control panel? Any other likely causes?
Thanks for your attention and hope you can help.
Will
