Hoover Frost Free Fridge Freezer HF27C
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hoover Frost Free Fridge Freezer HF27C
Viewing 1 post (of 1 total)
  • #37696
    RCT
    The machine is running continually, If I turn the temperature setting to zero it switches off. I reset the temperature to 3 and the machine stays off until the temperature has fallen to below that setting and starts up. However it runs continuously.
    Food in the fridge is not freezing, I was told it could be the pcb or sensors. The machine is 2 years old and the pcb is ITW ISPRACONTROLS CU 29361 (97052963).
    It has been mentioned that if the fridge is not freezing then it can’t be the pcb, does this mean it is the sensor for cut off at required temperature setting level.
