Hoover H1 Pet
  • #30435
    Flyer
    Our daughter’s The One Pet hoover switches on ok then cuts out, then comes on again and keeps switching on and off. Is there a thermal cut out or is it a case of replacing the motor control board. If so do you do replacements. model No H1PET 100. It’s about 2 years old.
    #227190
    Dave_Conway
    Re: Hoover H1 Pet
    If you haven’t done so already, I would check the filters as these can cause the motor to overheat when blocked 😉
    Failing that, it’s probably the motor itself 🙁
    #227191
    petalpop
    Re: Hoover H1 Pet
    if it keeps cutting off as soon as you switch it on it is probably just the lead has a break in it
