Hoover H160 Fault Code
  • #88229
    mlodmore
    Hello – I have a Hoover H160 EUK and the superwash, extra rinse and time countdown LEDs are all flashing on/off once per second.
    Can anyone advise me what this might be.
    The front counterbalance weight bolts sheared off so I fitted a new tub front and reassembled the machine. It worked fine at first but I had got the arm that connects the timer to the soap dispenser drawer connected to the wrong hole on the arm so lifted the lid to move it and now I’m in the position as described above.
    To be honest this machine is 14 years old so owes me nothing but as I have just spent £100 on a tub front, seal, bolts and a door gasket it would be nice to see if it’s anything simple before I (reluctantly) look for a new machine.
    thanks,
    Michael
    #437418
    mlodmore
    Re: Hoover H160 Fault Code
    “Fixed”
    Machine seemed to have got into a weird loop which I managed to clear by a mixture of power cycles and holding down the Start/Stop button.
