Hoover H160E – not filling
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover H160E – not filling
  • #49509
    vic_c
    Back again for our trusty old H160E. Think this one may have me stumped though.
    Machine not used for a couple of weeks (maybe it’s sulking) now when
    coming to use it, it refuses to fill.
    What I’ve checked:
    Water supply – disconnected feed and ran into bucket – plenty of pressure.
    No sign of blockage on inlet filter.
    Checked continuity of inlet valve (about 3K) – double checked by jumping
    mains onto the terminals briefly – water flows OK then.
    Pressure switch: Blowing into the air feed operated the c/o switch (one click)
    “making the two main connections), further presure makes connection to the
    additional contact (overflow?) but no second click. Slightly suspicious as I
    seem to recall that there is usually two distinct clicks but that may just be my
    dodgy memory!
    Additionally checked the Brushes (had a fault with these once before when they were worn but they seem fine).
    Selecting the rinse program the machine seems to start to think about
    working and I detect a whirr from the programmer and a click when I think the water would normally fill but a meter across the inlet valve shows no sign of activation voltage.
    If a spin program is selected then the machine seems to function OK
    so I think this confirms the brushes OK and I presume rules out the door
    safety interlock.
    I guess that only really leaves the control board… a quick visual of which shows no obvious sign of burnt out components.
    Before I call in the cavalry any further useful suggestions?
    #300116
    suedehead1
    Re: Hoover H160E – not filling
    have you checked the pump is working.
    the pressure switch is one click.
    i would normally say plug out but by jumping mains onto the water valve you seem to be quite content with electrocution.
    #300117
    vic_c
    Point taken about plug out – but don’t worry, I am confident with what I’m
    doing… plug out connect up temporary test jump lead (via isolation transformer) then a quick flick of switch whilst well clear of the machine
    just long enough to confirm operation.
    Think the pump is probably OK as the machine was empty from it’s last
    run but I’ll double check tomorrow. I’ve changed the pump before after
    it got jammed and suffered a trauma.
    Not sure why a faulty pump would stop the machine filling though – I seem
    to recall it was quite happy to fill last time the pump went south.
    I’m also slightly suprised that there seem to be no error lights/code evident
    (not that I know how to interpret them!)
    Thanks for the pointer – let’s see what happens tomprrow.
    #300118
    suedehead1
    some machines are wired up in such a way that if the pump is open circuit it wont fill as in why fill when i cant empty.
    #300119
    vic_c
    OK – checked the pump – DC resistance 200 ohm (measured as 190 when
    I fitted it before so I think thats OK).
    Hmmm, haven’t checked (or ever repaced as far as I can recall) the heater;
    would that also feature in part of the start up checks?
    I’m also having second thoughts about the door switch – there appear to be
    1 green and three white wires going to it.
    The green I have traced to the control board (PN) connector. The three
    whites are trickier to trace but one of them goes to the indicator lamp.
    I find no continuity green to white with door open or closed. Guess I need
    to get it out of the machine to have a closer look.
    There is a 5 minute safety timer on this model – not sure how that is
    activated
    #300120
    vic_c
    Quick update, have now checked out the door switch.
    3 connections: green to pin 1, single white to 3 and white pair to 2.
    Pin 3 is connected to Live when machine is on with program selected.
    Approx 1K between 1 and 3. Current from pin 3 to 1 operates a heat
    activated delay switch to connect 3 and 2 together so looks like the switch
    is OK after all.
    Time to pull the beast out further and check the heater.
    #300121
    vic_c
    OK – heater checks out OK (about 27 ohms cold).
    Further examination of the control circuit reveals that the fill valves are
    neutral switched by triacs and get their live in series with the pump.
    This means that if the pump is o/c then they cannot operate. However
    I’ve already measured the pump DC resistance as apprx 200 ohm.
    (double check by connecting mains direct to pump – it runs taking approx
    180mA) so looks to be OK.
    This design therefore means that anytime the pump is activated the fill
    valves are automatically forced off. Now wondering if I have a fault that
    is leaving the pump running all the time thus disabling the fill valves.
    If this is the case then the question is whether its the control module
    faulty leaving the pump activated or the programmer incorrectly telling
    the control module to do so. Not sure which is most likely.
    Didn’t think to verify this before – time to put the bits back together and
    have another look.
    #300122
    vic_c
    Success! – (apologies for numerous replies to my own post but the info
    may be of use to other browsers of this forum).
    Put everyting back together today and Lo it now works OK.
    My suspicion is either the door interlock now working correctly after my
    removal, close inspection and re-fit; not entirely convinced as my first
    impressions that this must have been working as the machine was happy to spin.
    Then again perhaps it was the stern talking to I gave it last night with
    threats of the landfill – and a few expletives!
    More likely there was a poor connection somewhere and my removal and
    refit has re-made the connection. I did notice that the “EN” connector to the control module was a bit loose on re-fit so I “re-sprung” the
    connecting blades to get a firmer fit. I also cleaned up the pcb
    connectors too.
    Considering all the symptoms, I suspect that this connector from the
    programmer knob may have been the most likely cause. I presume
    these connections are low voltage and perhaps a combination of
    poor connection plus not being run for a couple of weeks may have
    allowed sufficient oxidation to buildup to confuse/corrupt the command
    signal thus leading to the failure to activate the fill valve.
    Good news is that it now seems to be OK and is presently busy coping
    with a bit of a backlog – should be a good test.
    Also hasn’t cost me a penny to fix – just lots of time but being recently
    redundant and now early retired time is something I have plenty of
    (as opposed to money!).
    The irony is that I now know more about this machine than ever since
    we bought it 7 years ago. May not be the latest and greatest but with
    service information so scarce on modern machines I’m happy to stick
    with it until it really is time for the scrapper.
    Thanks to those who offered troubleshooting advice and information
    (and for the kind concern over my safety) this really is a useful and
    helpful forum.
