hoover h160e pcb repair – which pump triac – is this ok?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover h160e pcb repair – which pump triac – is this ok?
  • #65433
    gandh1
    been out to a hoover h160e – 80
    wasnt draining or pumping, so first stop filter and carbons, filter clean, brushes worn low so replaced carbons and tested. still no drain but had spin.
    so put a connect askoll pump on as old plaset type was dead and bulging – overheated. still no drain so found main pcb (side mount) and one of the legs of the triac on TR5 is burned right out.
    spec on triac was:
    MAC
    97A8 or 97AB
    243
    anyways, not big into module component replacement but took out a scrappy bearing failed 7.5k nextra last week, so harvested its pcb before ditching and its got same size triacs, but with different codings. anyhoo, soldered out the triac in the same TR5 position, and its got this on it:
    (logo – st?)
    ZUG07 / ZU607 / Z0G07 / Z0607
    MA
    75 521
    What i wanna know is it gonna be compatible? according to connect both machines can use same pattern pump…
    anyone (mike?) help me out here ?
    #360471
    Allsorts
    Re: hoover h160e pcb repair – which pump triac – is this ok?
    The triac is MAC 97A8 .. We have some of them in stock if you can’t find a reclaimed one.
    George
    #360472
    gandh1
    had a look but nope not come across one, dont really want to buy 50x or so of tinternet. so how much £££ for 1x inc p&p sir allsort?
    #360473
    Allsorts
    MAC 97A8 Triac for Hoover Candy module repairs
    There is the item and it is showing we have 9 left in stock… How many do you need?
    #360474
    gandh1
    didnt know u were on ebay.
    just the one is required, im confident enough i wont balls it up twice 😀
    #360475
    Allsorts
    PM
    #360476
    gandh1
    have found a/s! cheers. have also since spotted a wil133 test module with “mac-type” triacs attatched. gonna heat one of those out and try it. if the hoover completes 3x test runs ok ill get a replacement “mac triac” off you to put back on my test wil133 pcb 😛
    cheers dude!
    #360477
    Allsorts
    Before you try it.. download the datasheet for the triac mac97a8 you have and the one you are going to try replace it with so that you can see the operation of each… These mac triacs are Logic level Sensitive Gate triacs. I wouldn’t want you to trial the wrong chip and destroy your board.
    #360478
    gandh1
    ah hah, the 133 triacs are mac97a8 too, but they have a different 3 digit number under it – 537 or something iirc, is that just the batch code?
    #360479
    Allsorts
    not sure… Mac97a8 is the important part.
    George
    #360480
    My God, things must be tough going up there, wherever you guys are!
    MAC97 Qty 1 @ 46p + vat including g’teed next day delivery. OK you need to open an account. It takes a few minutes and maybe you have to give them your card details. They never hassle you for more business by phone – I spend about £30 a year and all I get is an occasional email which I just delete like the Tesco ones. How can you run a shop and still have time to desolder 50p components?
    Mike.
    #360481
    gandh1
    everyone knows i dont sleep 😀
    and it only takes me a few seconds to pop one out (?!) if im lucky and dont have the old shakey hand. i was fixing the van keyfob blipper at the same time anywya as the micro switch had snapped off
    takes longer to warm the iron up…
    #360482
    Allsorts
    leavemetogetonwithit wrote:My God, things must be tough going up there, wherever you guys are!
    Mike.
    That’s a Mac97A8G Mike… Different monster so I am informed (by RS & Farnells)
    George
    #360483
    George
    Not time to look into it just now but I cannot believe that the difference between two components, both labelled MAC97A8, would be at all significant at the level we’re talking about. If it was, there would be boards blowing up all over the plan….
    mmmmmmm………Hang on a minute, maybe you’ve hit on something…. 😆
    Mike.
