Hoover H3D 485TE washer dryer
Home Forums Public Support Forums General Enquiries And Questions Hoover H3D 485TE washer dryer
  • #98460
    Welshorb
    I have just purchased a Hoover washer dryer, model H3d 485TE. When I select high heat to dry towels, it sets a time of 3 hours 50 minutes. Does anyone know if this time can be reduced as I don’t need to dry them for that length of time. Can that time be changed manually on the machine? Many thanks in advance, Rachel
    #472435
    only if you can set a dryness on the machine iron dry, cupboard dry etc
    or you can sometimes set a timed programme
    Welshorb
    electrofix wrote:only if you can set a dryness on the machine iron dry, cupboard dry etc
    Yes, I can select extra dry, iron dry or cupboard dry, but they are all really long drying cycles.
    #472437
    kaibart
    From what I am reading in the instructions it doesn’t show a setting so you can put it on for a hour to dry ,but having said that you can download programs to machine so you might well be able to do it through the hoover wizard app
    #472438
    Welshorb
    kaibart wrote:From what I am reading in the instructions it doesn’t show a setting so you can put it on for a hour to dry ,but having said that you can download programs to machine so you might well be able to do it through the hoover wizard app
    I couldn’t get the app to work. I registered an account, but it was asking for a user name and a password. When you register, it doesn’t ask you to register a user name, so it kept saying there’s a problem with the user name or password so I couldn’t even log into it. You also need NFC on your phone to be able to send things to the machine, and I don’t have that
