Hoover H3W58TGGE flashing control board
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover H3W58TGGE flashing control board
  • #103207
    mikehha
    Hi all can any one tell me if hoover are having problems with there pcb `s as this is the second one this week where the control card all flashes. can find no loose connections no burn marks Heater not down to earth anything else should I be looking at ?
    #492205
    big problem with hoover is even their tech site is a pile of poo
    does it flash on turn on or as programme progresses
    mikehha
    Hi dave she said it started flashing halfway through ( she thinks) now it dose it as soon as it is turned on at the plug? they say it could be an overheat problem so I tried another thermistor still the same.
    #492207
    ok
    did you disconnect heater just to make sure its not that
    Check board for bulging caps
    other than that gets harder. you can do silly stuff like check pump winding , motor coils etc but in the end you may well have to give up and scrap it
    mikehha
    yes ! thanks dave. have done all that. I might lend her a m/c and bring hers back to the workshop and play .
