Hoover HC6150MUK
  • #50743
    euro
    Got the above machine to look at, customer says its just siting with the pump going all the time, it dont matter where you put it on timer. Will this be a pcb or timer fault?
    Andy
    #305820
    timdowning
    Re: Hoover HC6150MUK
    When its sitting there just pumping has the door locked?
    It may say it has but try opening it.
    It could be door or door lock issues.
    #305821
    euro
    The doors locked Tim, it does not matter whereabouts you have the timer on the wash it just sits pumping, when they move it to the end of program it keeps going, they have to switch it of to stop it
    Andy
    #305822
    Motorised selector switch is worth a punt (Cheap), failing that PCB. Checked p/sw not stuck on flood protect?
    Worth also checking for short circuit water valve coil. (Yes it does happen occasionally.) If pump supply is routed via valve, as is sometimes the case, this is what you get.
    Mike.
    #305824
    euro
    Incase anyone else comes across this it was a fault on the module
    Andy
