hoover hca 310k fridge/freezer drain hole icing up
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum hoover hca 310k fridge/freezer drain hole icing up
  • #29248
    jim1976
    Hello all,hope someone can help me,the drain hole in the back of the fridge compartement is icing up and causing a blockage and causing the fridge to leak.Ive defrosted it,but the problem still occurs.I have read a previous thread in which a lady had exactly the same problem,and i gathered from the answers that either the lining had a crack in it,and can not be repaired,or the tube running out of the drain hole had a crack in it and this could be causing the problem.Can anyone out there please tell me what the problem is ,if it’s easy to fix,and if so,how to fix it.Much thanks :rolls:
    #222480
    Re: hoover hca 310k fridge/freezer drain hole icing up
    Hi Jim,
    This article explains about cleaning the drain
    Once you know it’s clear then it’s time to look at other things.
