Loopey, thanks for your attachments.Much appreciated. HOWEVER, went back armed with instructions. Measured 168mm down and 172mm in and dig out insulation. Guess what, nothing there !!!!
Are there any other positions it might be ?
Starting to wish i hadn’t seen this one
Hi Bob
I have tech note 004FR-09/20/2004 updated feb. 2007 which shows dimensions in above post. Obviously once i had started i opened up the hole a bit but had to know when to stop as there was nothing in this area. Any extra info would be greatly appreciated.
Hi Loopy, One of the ones you sent was dated “update Febuary 2007” but measurements the same as anything else i have found.
If anyone comes up with something different i will send it you. Thanks again for trying. Paul
