Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover hd vision 1200 timesaver mode
- This topic has 14 replies, 5 voices, and was last updated 14 years, 10 months ago by
chris knights.
June 6, 2011 at 7:09 pm #63217
chris knights
Participanthi please can some one help me as i like to try and fix things my self and now stuck with this ,
i own a hoover hd vision 1200 washing machine and half way through a wash the machine stops and goes onto time saver made and flashes ,
i have checked the heating element and changed the control panel and still not working right , can some one point me in the right directing please
many thanks chrisJune 6, 2011 at 8:53 pm #352996kwatt
KeymasterRe: hoover hd vision 1200 timesaver mode
Hi Chris,
Can you give us the model number?
June 24, 2011 at 8:45 pm #352997chris knights
ParticipantRe: hoover hd vision 1200 timesaver mode
sorry been busy with work the model number is VHD 822/1-80
June 24, 2011 at 11:04 pm #352998kwatt
Cautionary note: don’t assume the electronic control panel is faulty if there’s odd flashes.
How many flashes is it?
June 25, 2011 at 8:09 am #352999chris knights
once it stops half way through a wash and it flashes 3 times on time saver , i have checked the heating element and it works , also change the controlpanel thinking it was a programme problem and still having the same problem
June 25, 2011 at 11:24 am #353000Martin
chris knights wrote:also change the controlpanel thinking it was a programme problem and still having the same problem
Blimey, that’s a bit extreme fix when the fault is simply a drain time-out error.(i.e Pump blocked or drain outlet restricted) 8)
June 25, 2011 at 11:35 am #353001kwatt
Yup, as Martin says, it’s a drain timeout error.
The control module will almost certainly not be faulty.
There is a known issue with the wash heater in these machines that Helo pointed out in another thread where they have a slight earth leakage and trick the board into thinking there’s a drain error. The element you can get here:
http://shop.ukwhitegoods.co.uk/Washing+ … ement.html
It’s almost certainly the cause. Can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but I’d be very confident.
HTH
June 25, 2011 at 2:14 pm #353002chris knights
you guys have been so helpfull and very greatfull for quick to answer back , i will get the pump off to see if its blocked plus check the pipes to see if any of them are blocked :tright:
June 25, 2011 at 4:07 pm #353003chris knights
update
i have taken the pump out to have a look and all the pipes are clean and clear the pump spins freely and replaced all back and put on a wash as it didnt work , timer saver again , i dont get paid till tuesday , would you say its worth getting a new element as stated it does suffer a earth leak tricking the control panel to come up with a drain error ??
June 25, 2011 at 7:35 pm #353004kwatt
Hi Chris,
You’ve got four choices the way I see it..
Get an engineer in to look at it for you.
Get a hold of an earth loop meter to check the element although, you will either need to know how to do that or know someone that does.
Take a punt on the heater, which as stated, is a known issue.
Replace the machine.
I reckon that’s about it really.
HTH
June 30, 2011 at 4:15 pm #353005chris knights
KWATT i love you 😀
i got a new element for that link you posted , just fitted and put on wash and im over the moon , it works and it was the element , my misses will stop nagging now , cheers for all your help im a happy guy now , and will spread the word about the forum , top marksJuly 31, 2012 at 12:28 pm #353006Heleniki
Hi please help school holidays and football mad son and no washer.
this sounds like what is happening to my washer, husband checked all pipes and it will spin if put on seprate spin/rinse cycles! My washer is a Hover Hd vision 1400AAA VHD8142. Flashing 3 times! Will fault be same as above?
July 31, 2012 at 4:32 pm #353007Heleniki
Sorry it’s even doing it on those cycles to now!
August 1, 2012 at 9:43 pm #353008helo_75
if your not sure, disconnest the heater completely and see if it spins with no errors
bang on heater fault if its draing properly
and im a hoover/candy engineer!
August 2, 2012 at 10:20 pm #353009Heleniki
thank you is it hard to find/change?
