Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover HD Vison
- This topic has 12 replies, 5 voices, and was last updated 13 years, 8 months ago by
Heleniki.
August 2, 2012 at 7:01 pm #70766
Heleniki
ParticipantHi i have a Hoover HD Vision 1400 AAA VHD8142 washer machine thats playing up! The machine keeps stopping and the 1200 and time save lights flash 3 times! My husband has checked pipes and filter! Has anyone got any ideas what it could be?
9 year old son who is football mad, school holidays and no washer 🙁
August 2, 2012 at 7:31 pm #378881A1engineer
ParticipantRe: Hoover HD Vison
Pump time out, check filter for blockages
Filter is under kick panel at bottom of front panel
August 2, 2012 at 7:49 pm #378882Heleniki
Hi, My husband has already checked its fine, no blockages.
From what i can tell the washer fills and starts cycle fine then water pumps out and then stops and lights flash.August 2, 2012 at 9:16 pm #378883helo_75
faulty heater… well documented on here…. and rofl @ behind the kickplate, theres no kickplate on a vision hd
August 2, 2012 at 10:02 pm #378884Heleniki
The little square pull down plate at the front where the filter is thats what my hub checked, and pipes. Faulty heater? is there a link sorry im new to all this and a women 🙂 I was left to try figure it out while hub went to football lol!
August 2, 2012 at 10:05 pm #378885helo_75
the heater gets a slight earth leak, which fools the machine into thinking its still full of water when its not, a new heater is required
August 2, 2012 at 10:07 pm #378886helo_75
washing-machine-forum/hoover-vision-1200-timesaver-mode-t64650.html
August 2, 2012 at 10:08 pm #378887Heleniki
Thankyou so much for all your help!
is it easy to replace? my husband is a mechanic and my dads an electrician do you think between them they could do it?August 2, 2012 at 10:24 pm #378888helo_75
just make sure its unplugged, take off the back, and its there , just above the motor,a bit to the right… its not a bad job as long as the nut is slackend and the seal is loosened off
good luck
August 2, 2012 at 10:32 pm #378889Heleniki
Thank you
Ive passed all info on to my husband and betwwen kids football/training this weekend he will have a look, thanks again for all your help its much appreciated 🙂July 6, 2014 at 8:02 pm #378890Heleniki
My washer has stopped and is coming up with this error again!
I put it on drain setting to empty so hubby could have a look and it’s not draining! Any ideas?July 6, 2014 at 8:29 pm #378891Martin
Check the pump filter. See user instructions.
June 24, 2015 at 4:43 pm #378892mike@Great_Baddow
I had similar problem with Vision VHD8142. All programs started then stopped after wash part of cycle; with with Timer LED flashing 3 times and 1200 spin speed. This suggests drain out problem, but as others have pointed out can be heating element with earth leak sending false message to controller.
I knew the drain out was OK as you could switch off machine and start on rinse cycle which it did OK. Changed heater element (cost £23) and all works fine now. -
