Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover – HDC6 dryer – Help requiered please.
- This topic has 11 replies, 3 voices, and was last updated 15 years, 11 months ago by
bungle666.
May 14, 2010 at 7:59 pm #54617
bungle666
ParticipantOk, My HDC6 has died!! LOL well not quite, you fill with washing set the time hit the button and nothing. the clock ticks away but the drum wont rotate…
So, i emptied out all the washing, and did the same again. still nothing, you cant even hear the motor turning… HMMMMM
top off time… hit the button then give the drum a spin by hand from above BINGO it turns, but not as fast as it should.
i hear it could be the “start capacitor” thats at fault, so my firs question is…. is the “start capacitor” next to where the mains cable comes into the machine body??
and second question, any ideas what (if anything) else could be the problem??
thanks peeps
B..
May 14, 2010 at 9:51 pm #320342iadom
ModeratorRe: Hoover – HDC6 dryer – Help requiered please.
It could well be the motor capacitor, the device next to the mains cable is the mains filter, that just stops radio and TV interference.
As this machine is actually a Candy appliance their dryers are often named as the worst designed tumble dryers on the market from a servicing point of view by most of the trade.
The motor capacitor is mounted on the side of the motor itself, a considerable strip down is required to access.
A capacitor change on the majority of dryers on the market takes 10 to 20 minutes at the most, this one is a real PITA. :rolls:
May 14, 2010 at 9:57 pm #320343bungle666
ParticipantRe: Hoover – HDC6 dryer – Help requiered please.
iadom wrote:It could well be the motor capacitor, the device next to the mains cable is the mains filter, that just stops radio and TV interference.
A capacitor change on the majority of dryers on the market take 10 to 20 minutes at the most, this one is a real PITA. :rolls:
ahhhhhh i see your a local lad!! im in oldham 😉 thanks for the advice bud, ill commence a strip down tomorrow then.
other than the motor and this capacitor have you any ideas what else it could be??
for the sake of £3 for a cap ill change it, but in my book if it still wont work that only leaves the motor and TBH i dont think its worth changing on a 7 year old dryer!!
cheers for the help mate
B..
May 14, 2010 at 10:00 pm #320344iadom
If it runs once you have pushed the drum then its odds on the capacitor, and as you say well worth a punt.
A real pig of a machine to work on though. 😥
A Shaw Gorby myself, although I was born a Rochdale Masher and for many years was a Royton Sevener. 😉
May 14, 2010 at 10:18 pm #320345bungle666
iadom wrote:If it runs once you have pushed the drum then its odds on the capacitor, and as you say well worth a punt.
your not joking!! i cant figure out how to get into the base to get at the motor!! i guess ill just have to start taking screws out till it all falls apart!! LOL
iadom wrote:A Shaw Gorby myself, although I was born a Rochdale Masher and for many years was a Royton Sevener. 😉
ahhhhhhh just down the road from me then, im yorkshire saddleworth exile currently living in strinesdale!!
cheers for the help mate, if i start to struggle then an engineer it will have to be!!
B..
May 15, 2010 at 1:24 pm #320346iadom
Everything is accessed from the front, have fun. :rolls:
May 15, 2010 at 2:35 pm #320347bungle666
iadom wrote:Everything is accessed from the front, have fun. :rolls:
ive had fun, done some bleeding, got the wife in to help as she has skinnyer arms than me, got the component changed, switched on and STILL THE BLOODY SAME!!
no different…
so folks, is there anything else i should try before i scrap this heap of shit drryer…
cheers!!
B..
May 15, 2010 at 3:28 pm #320348iadom
Is the drum free to turn, you should be able to turn it without to much force although it should not actually ‘spin’ freely. It may be a faulty motor but induction motors are normally fairly reliable and often give off a burning smell if they are failing.
Its not one of the best machines on the market TBH.
May 15, 2010 at 6:23 pm #320349bungle666
iadom wrote:Is the drum free to turn, you should be able to turn it without to much force although it should not actually ‘spin’ freely. It may be a faulty motor but induction motors are normally fairly reliable and often give off a burning smell if they are failing.
errr yea, it turns no problem by hand, but there is some resistance too.
the thing is it cant be that bad a machine as it has done 7 years of absolute hammer and minimal maintenance at best, and all its needed is a starter relay board about 3 months ago!! LOL
the motor is an absolute ARSE to get too, its been bad enough trying to get to the capacitor!! LOL
Oh just thought when it does run the clock is VERY noisy and the reverse cycle doesnt seem to fire either, it just runs continual in 1 direction!
B..
May 15, 2010 at 8:20 pm #320350iadom
Seven years, pfft,
I changed a belt on a Hotpoint dryer last week, it was the first time it had been changed. It was 27 years old so I guess it wasn’t up to much.
A decent, reliable tumble dryer should be the most basic, simple machine to produce but the quality of the low to mid range stuff on the market these days leaves a lot to be desired. 😥
You could be throwing parts at this without much success, if you have managed to get 7 years out of it then it may be time to move on.
May 16, 2010 at 11:20 am #320351bungle666
Participanti think your right mate. time to retire the old girl!!
ho hum….
thanks for all your help pal, it been really appreciated.
right im off to the scrappies for a weigh in!!
B..
May 16, 2010 at 1:55 pm #320352Higher-water-level
iadom wrote:Seven years, pfft,
Afternoon Jim :wave:
I can beat the Hotpoint, I have a fully working 32 year old TI Jackson compact drier and its never had any parts, could do with a lick of paint, a summer project me thinks, if the Yorkshire weather ever improves!
They certainly don’t make ’em like that anymore. Its very sad really as appliances like this make tremendous value for money and give little to no trouble through out their very long life span.
Oliver.
